Uh...mmm....ok well lets say i dont run an eq. i want to run 4 amps. front, rear door, rear deck, and sub woofer. i know how i would split all the power and the remotes but where would all those rca's go to? Still planning to keep it stock
LoL....yeah, a 6 channel and a monoblock. But with what you're working with, it will work. You want to make sure to pull a full range signal to your LOC. Can't remember on the Lexus' which lines were the full range.is there a better way?
Definitely with that many amps. 86 to turn on lead, 30 to constant 12v, 85 to ground, and 87 to amps.for the remote wires i should use a relay to distribute the power right?
