heres a quick rundown:
i swapped in a new motor and installed a z7 kit. i attached all the power and ground wires from what i remembered and when i turned the key to accel on theres no power....not even interior lights come on with the door opened. the battery was fine a week ago when i had to shift into nuetral and push the car a bit up my driveway. so now the keys stuck cause of the trans lock which needs power to unlock and be able to get the key out.
i looked through all of the wiring and im stumped. ehres what i doubled/triple checked:
-alternator while connected to the alternator bolt
-ground wire attached to the motor to trans bolt
-small ICM ground wire i grounded to the chassis
-cleaned the direct ground connector from the neg terminal off battery
-starter wires: attached the 2 medium sized connectors and the large wire connector onto the large post off the starter. the smaller purple wire i have by itself on the smaller post. both posts are tightened down
i checked the voltage from around the area and got a steady ~11v. heres where i checked:
-neg terminal and pos alternator
-neg terminal and pos terminal
-pos alternator bolt to neg ICM ground
-pos starter post to tranny to motor ground
-pos terminal to ICM ground
-neg terminal to pos fuse box
-pos fuse box to ICM ground wire
im at a loss. theres current going through the motor but i cant seem to get any power to the rest of the car, ie-inside the cabin or being able to power on the dash etc. any help is greatly appreciated!!!!!
