Help me pick a wheel.....
20s are a good size for your size vehicle. any width restrictions you want to abide by? i'm going to assume 9" wide or less so they fit fairly easily.
Well, it was between 18 or 20 inches for me. 20 inches you lose minimal performance if any.. Width restrictions are exactly what you said. I do not want tires that "poke out" or take away from the car. I personally am leaning with wheel number one as well.. Just wanted to get more opinions...
Anyone know of a good web site to look at other wheel options?
the first wheel looks a little wide. what size does it come in? website?
depends on how much you want to spend as well. a GOOD set of wheels alone will set you back $2k+.
actually looks like in 20s you can get them in 8.5", 9", 10.5", and 12" wide. they are called niche sportiva's.
both the 8.5" and 9" wheel come in a friendly +35mm offset, which is good for you.
the 8.5" is going to be 5x115, the 9" will be 5x114.3. both will work, but just to be specific so you're aware.
i like them and i think that either of those sizes would look good running a 245 wide tire.
I went to hotwheelcity as well when I was first looking for rims. You can find a nice gently used set for around 7-800 tho on Craigslist. Maybe driven a season or so. As soon as you pull away from there the value just goes down so much to where idk if I'd spend 2 grand on rims. Is 1500 including tires?
You don't buy rims unless they're super cheap or high end if your thinking its going to maintain value. Plus most will rather just hit up Craigslist and spend $500 on curbed no name rims rather then buying from a well known company. Shrugs
