Heads up Display is Dim
2001GPGTP
Hey a quick ? My HUD recently started getting dim and after researching a little it could probably be needing to be resoldered? I'm not that handy so would this be a somewhat easy task to do ? Or should I just not mess with it ? Again it's getting dim during the day. Any suggestions are welcomed .
Even if you don't have great soldering skills its not too bad. I did mine over a year ago and its still nice and bright. The solder points are pretty easy to hit with not much around them if I remember correctly. I had a harder time getting the dash pieces apart without breaking anything.
Sent from my DROID RAZR using Tapatalk 2
It's super easy. Once the iron is up to temp..all you have to do is touch the two locations for the piece. You touch one..and see the solder move a little.. move to the other and poof..done.
I need to do this as well - mine isn't just dim, it's typically out all together...then comes on for a bit, then fades out completely again. My main concern isn't the soldering part - it's taking the dash pieces out. Never done that on this car, and not sure how...
