headers
if you get a 10% overdrive, the oil filter will need to be relocated, 5% doesn't take any extra work and is cheaper.
unless they come out and measure the pulley, you can get a press on 3.4 , it looks stock, wink wink. theres one for sale in the sale section.
headers are going to lower your boost to about 5 psi. the 3.4 will put it back around 10 psi.
if you want to run its very best it needs to be tuned. stock tune is crap. trans tune also helps.
No you just need the spacer for the oil filter adapter or you can dent the oil filter. I had an od balancer and all I used was the spacer and had no issues with leaks.
Sent from my SAMSUNG-SM-G870A using Tapatalk
ok
yes they do measure the supercharger pulley
where to get the crank pully and spacer and belt
thanks you are give me some good things
I know zzp sells the balancer and the spacer kit, they won't tell you what belt you need and for the life of me I cannot remember what belt it was. I left the packaging from the belt in the box in the trunk so I wouldn't forget in case I ever needed a new one, and I left it in the trunk when I sold the car.
headers lower the boost, so a 3.8 pulley you'll see 5 psi tops, this is where the tuner comes in handy cause now the game is to turn the timing up till it starts to show kr, then back it down a bit till theres none in a second gear pull through third.
you allowed to run e85, or race fuel?
if you get kr revving it in neutral or park, you need a another blower, its bearings are shot and the rotors are touching, its false kr, but still cuts your timing.
take the sc belt off, then see if you get kr when you rev it, if not, bingo new blower time.
That doesn't mean the blower is the problem. The motor makes significantly less torque without the blower belt on.
if you read any of anything, this is in park, revving it. tq is not a issue here dummy. a bad blower is. cause your not making any boost revving it in park are ya?
