Header Install
I didnt remove any cooling lines, idk where the leak is comming from, the trans dip stick is held in by the nut but some how it fell out of its hole. the coolent turned to mud, cuz when you mix dex cool and any other type, thats what happens, so the owner before me must have done that, i have only had the car for about 4 months and now it wont start :(
when i put the headers on, i started the car and it died, i didnt have the motor mounts in so i thought maybe thats why it died, but when i went to start it again it just cranked
you have had the car for four months and have never looked at the coolant before? I assume you can just drain this, flush it good and refill it if it is not a oil/coolant leak and is just a dex cool mixing issue........
just sayin, maybe he undid something and didnt put it back. theres no reason for a car not to start just by putting headers on and not touching anything else. if you took the tb off make sure everything is connected...
check the wires on the starter anyway, maybe one is grounding.
this is what i think happend, so i'm gonna look into it more and take out the headers :( for now
Need to double check everything, check your O2 sensor, make sure those connections are good.
As for the header hitting the fan, I donno what to say about that, all I know is I have a 1-3/8" radiator and TOGS and I can put my hand between the fan and header just fine.
Post up pics of what you did....
