gtpshawty's gtp.. (*KAILEYS PROJECT*) NEW ENGINE PIX THE REINCARNATION...IT LIVES
Re: gtpshawty's new gtp.. (*KAILEYS PROJECT*) HELPPP PG 4 ALSO NEW PIX
im going to get the water hose and run it accross the car later
very nice soaking your own car, i like it. jk hope you solved it
only way to find it... hell i can control and prepare for it to get wet... if it starts raining randomly im fu.cked
Since I am interested in the car, I was reading some of the threads of the guy who is selling his 99 in Jersey had posted about the car and he had a chit load of problems with his SR take a look at his threads and maybe you can get some useful info or tips there
Is that a green monte carlo in this picture?
So he painted it and put the 04/05 SS ground effects on it? Or did he get it that way?
Also, lemme know if you find a way to seal those holes up without welding them shut and still keeping them pretty hidden. Mine is black too and I've always wanted to remove the door bumpers, but hell if I can afford to weld em up.
should be raining now....
Just a tip for your leak issue. If it is the sunroof drains, DO NOT use the air compressor to drain those lines.
I did that to my G6 and it blew the lines off, I didn't know it.
Found the leak a couple months later and ended up with a soaked interior.
So 3 days and $350 later, it was dry.
Due to it happening in December, and I didn't have anywhere inside/warm for the car to sit the dealer had to keep it and pull the whole interior out to let it dry.
So for future references, I think they have a little 'snake' that they use to clean those lines if they do get clogged up.
yea zero it was pouring down... thunder and lighting.... and danielle i wish you said that two days ago.. i blew it the the air hose.... but it didnt leak today... but i did have a water smell in the car... strange huh.. well i did leave the sunroof open while it drizzled so im guessin it was that... but idk
so if the exit of the lines are in the door jam, where are the beginning of the lines? somewhere in the sunroof track??
yeah there a trough if you open it up and look at it, but maybe you did blow them off or did you use the hose?
it rained and nothing came thru the car so looks like you were right
look in the corners of ya sunroof.. open it and look in the left and right corners.. you will see two little holes
me too.. lol now the insides wont rust.. im still replacing the carpet and seats... the water has ruined it.. well the past owner ruined it.. cutting it up for some odd reason... smh..but thankx.. ill have more pix posted of the forward progress
