Going intercooled tomorrow (finished!)
Re: Going intercooled tomorrow checklist
Emm... How else do you plan on mounting the fmhe without removing the bumper lol..
You tore part the top half of your motor surely removing a bumper won't be challenging.
I know I know... u are right i'll do it in the morning as far as the pump where did you guys wire it to? I can use the ignition fuse correct for power and ground it to the either the battery or any where on my subframe correct?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Run a relay. Seriously.
Go to any auto parts store and get a 4 pin relay.
I used the fuel pump relay as my switched 12v to tell the IC pump to turn on.
Pin 30----Battery +
Pin 85----Ground (Battery - or any good ground bolt to frame)
Pin 86----Switched 12v (again, I used the fuel pump relay, or you can use any other switched 12v)
Pin 87----To IC pump +
Obviously you'll want to ground the IC pump to a good ground also.
Ok thanks man i'll do it today thinking about mounting it at the location
Update:
gonna finish this weekend its just not enough sunlight by the time of me getting hm from work i'll post when im finished if anybody have any other pics on where they put there pump that would be great
Dsmuts do you have a pic?
I cheated and ran the IC pump controller from ZZP. Worked well. Not sure if it really helped, but I can say I had it and it was there! LOL
I didn't take a pic but I just shoved them up behind the horns and threw a big ass zip tie around them.
How I mounted mine. 90* L bracket and zipties.
Pin 30----Battery +
He has one. It's still wired correctly to the pump I sold with the intercooler kit.
Yes sir which is goin in tomorrow if I can get some damn sunlight before I get hm was gonna mount the pump it the same way that you told me ls1 Camino but windshield washer reservoir is in the way damn 97's
Hey guys im hooking the hoses up to the core but the 97 alternator is permitting me from getting to the far end any tips? Anybody running intercooler's with 97 alt brackets im NOT taking the bracket off and buying a 99+ bracket and alt.. could I put a little oil or lube to slide the hose on the core? Any tips thanks
I slightly notched my alternator bracket when I did mine because I also refused to switch. I didn't need to take a lot off...so I made a 1" diameter crescent shape in the bracket webbing on the back side of the bracket only and smoothed the edges down. Worked and looked good.
Any pictures Sven? Please tell you got some...
I'm not sure...best bet is to check my build thread for Anna Nicole...may still be listed as the incredihoopdy. I can't access photobucket from work.
Checked out your build didnt see any pics but ima have to do some cutting on the bracket smh
