Ive said it a million times and ill say it again, working on GM FWD engines take the upper engine mounts off jack it up let it roll backwards while letting the jack down, set parking brake and you will have tons of room in the back to work with. Car rolls backwards, engine tilts forward, set parking brake. Piece of cake try doing that with a RWD camaro good luck with that #8 plug and hope you dont have headers:th_thumb-up: The bottom engine mounts and transmount arent solid take advantage of it.
Sorry to have to tell you.. but anyone that complains about a 3800 is a *****.
I ***** a little about the W body versus H body stuff. But that's only because I could sit in an H body engine bay with the drivetrain.
I always remove and reinstall the backwards bolt by hand. Man up if you think it's bad.
Basically if it's tough then you need to step back and look at it from another angle.
So does snapon. I have seen the extend able extensions never thought to buy one. I just pull the fuel rails tho. Oh and FYI you are sposed to pull the cab to pull the heads on a f-150 lol. It can be done with the cab on tho.
