ADrugDealer
Schooner Tuner
OUCH. Well the boost is getting turned way up after the trans goes in sooo? I mean is that high enough?
yeah but I need actual high horsepower cars to test this....
it's really difficult to get pictures of but I have almost 5thou deeper grooves on the stator support side of a GMR Gear from a 870 wheel horsepower car that would seem to indicate that the twisting and misalignment means that only half the chain is actually carrying the load. Without that misalignment more of the 7/8 chain will carry the load.
are 1 inch chain has not had near as rough of a life but even then you can see the inside shows more wear than the outside.
funny thing is is you know damn well GM knew it was a major issue so they fixed it with the 80e with the additional bearings, as well as the large ball bearing for the sprocket.
considering how large and flat half of the casting is around the 65e stator support I would guess that it's deflecting even at lower horsepower levels.
