Turbocharged400sbc
looking at these things and since im assuming that zzp only has 3.29 because they found the GM PM 3.29 tooling where the 2.93 sets are hobbed billet.
looking at RE'n em
id think that the morse chain would probably last longer if the engine had less leverage on it.
probably only one or two of ya that would be interested in that...probably more would be interested in the brace
any of you ****ers be interested in the norris brace? should end up far cheaper than the billet unit.
probably one of the best things since sliced bread, daves right, the case can deflect quite a bit, that whole half of the stator support has no support except for a long thin/flat section of casting. while not as sexy as his prototypes this still braces the stator support against the two meatiest parts of the case to prevent the stator/gear from twisting out of alignment.
my guess is that even a 7/8ths chain would last longer if the gear wasnt twisting and messing up what is supposed to be even tooth engagement.
i wanna show dave that there are at least a dozen folks out there that would want his brace
looking at RE'n em
