Fuel Pump Resistor Question
guitarguyucf
Ok, so I replaced fuel filter, fuel pump, fuel regulator, fuel relays and checked for vaccum leaks and it still does the same thing. Whenever I crank the car it starts up then dies. I try again and give it gas it starts up bogs down, then picks up. Its weird. So im kinda guessing fuel pump resistor now. Does this sound like it might be it? Also where the "f" is it? I popped the hood and took out battery and windshild fluid resevoir and its nowhere along that side.
Its by your battery, i never took my old one out its too much work really. Their is only one cable the new resistor will fit into by that area and that's your guy. I didn't even take the battery out so it shouldn't be buried too deep. Mount the new one where you see fit, as long as it is not contacting anything. Mine came with a mounting bracket.
Gm part number :88951182
My GTP is doing the same thing. Did you ever figure your problem out and what was the source? Any help would be greatly appreciated.
hey mines doing the same thing what year and motor? mine if you unplug the postive cable then hold key on start for a min then hook battery back up and it works so what can it be?
