Fuel Filter & lines - what to do?
Personally...I'd rather use a brake type flare/bubble connection. It stands up to the pressure rating you need whereas a compression fitting isn't rated for it.
true, but ive had them on every line possible over the years, never a failure. brake, trans, fuel. i got 2 on my car now for a brake line repair.
for 2 bucks each, its worth it to me.
But, to emulate that S-curve I'll need to use a nylon plasticy line, no? Which would connect to a connector attached to the filter, and a compression fitting wherever I cut off the line?
if you cant bend the metal line if its not soft enough to do by hand, you use a small metal pipe bender. small one is maybe 10 bucks or so. but a pvc tube or round pipe will also work. as long as your not making the turn to tight.
*head explodes from options and opinions*
I'll go to Hedahls after class and see what they have that I can get right now to repair it, at least for now.
@HOR,
What year/part # Impala filter would I need?
I can always Jimmy-up a hose to that - and if it doesn't work I can just get http://www.amazon.com/Dorman-800-054-Nylon-Fuel-Repairkit/dp/B000CIR1NY?tag=viglink25855-20 . I have to buy a new filter anyways, this way if the hose doesn't work I can still go to a better solution than the original set-up without buying another filter.
I don't remember what year. IIRC it was an Impala. I'll look when I get home
Sent from my LG G3
Well not gonna lie but you're cheap as hell....lol
Sent from my LG G3
Yeah, my brother did the same thing on his 90s Grand Am a number of years back and it held fine. I think I'll just watch it closely for a couple weeks and if it seems to be holding good I'll leave it alone - if it doesn't hold right I'll do something with compression fittings and such.
Thanks for all the help and input guys, really appreciate it!
