Frost White GTP
Re: GTP Coupe White on White "New Parts!!"
there's other DP's other then ZZP (keep in mind i have a catless DP) my DP i basically a straight pipe
im going to be selling my DP and Powerlog set up once i install my headers
yea if they have the right size piping they should be able to do a cat delete you want to get a u bend delete to then you will need an o2 emulator if you have no cat, might be easier to buy a catless DP from ZZP
And i know its probably right there on their website but I cant find the one you have. Could you put up a link?
its what ever one you want i have the 2 1/2" stainless steel one i think not sure i bought it new from a member on here and it hasn't changed colors or anything yet so i guess its stainless maybe, if your gonna mod more id go with a 3" though (keep in mind if you run no cat you'll need an o2 emulator)
got a package after work today..
ZZP fuel logs came in :)
ill get better pics soon
theres no better feeling then seeing a package that has ur new car parts in it
How much do you think you'll end up having wrapped up in the performance build?
under 2300 with out counting transmission parts, im trying to buy most of the parts used to save more money. im trying not to run to small of a pulley to where im gonna destroy my trans right away.
Re: GTP Coupe White on White "More Pix Uploaded!"
Strong join date to post count ratio. Car looks good brother. Keep it up.
Eddy posts like a mad man.
Car looks real good, I still will say remove the GTP badges.
And lower but hell, i'm not lowered so I can't talk.
thanks man!
i know i need to lower lol
and i will probably debadge soon not sure what im doin yet
i will lower once my performance build is done cant go to crazy with everything at once
i really want to put it on coil overs but im not sure if i want to fork over the money for it
so i might just go with lowering springs like i said im not sure what im doin yet
Looks really damn good. Though I do think it'd look better with a front plate inlay...break up alllll that white..
But this really is one of my favorite GPs
