Hello, I am new to this forum.
I have a 2005 Pontiac GP 3.8 Base Trim.
I have recently(2 weeks ago) had a mechanic to change all the spark plugs and wires, where he broke one of the spark plugs in the front and ended up
disassembling the front head assembly to take it out.
Then, the car had a leaking head gasket issue, so replaced that, and also a leak at the injector so the o-rings were replaced.
Now, I was driving on the highway(for the 6th time after the job mentioned above), and as soon as I accelerated ( 3500+ RPM) the engine light started flashing for about 5 seconds, and stopped flashing but stayed on.
So I stopped the vehicle to see what it was on the highway, Then I accelerated again and the car's rpm
went up to 3500 but from 3500 to 4500, it really struggled to go up, and the light flashed again.
Seems like the engine doesn't struggle under 3000 RPM, but to anything beyond that it stops at 3300 for a second then goes up to 3800 stops again, then goes up again and stops every 700 rpm or so.
and the engine light is still on.
Could the experts here help me diagnose what the problem might be?
Thanks
Thanks
