Konvinced89
For those not familiar with my angry rants, my car had an intermittent rough idle/stalling issue for years, and I replaced nearly every sensor in the engine with no results. MAF, MAP, TPS, CPS, IAC, plus the fuel pump/filter, and a bunch of other things. Short version: I had it down to the PCM or wiring, and I got an Overkill PCM. Problem solved!
Now, I want to get back to the fun part of owning a GTP. My other mods are a K&N intake, 180* tstat, modular pulley system(3.8 for now), 104 plugs, ubend delete, resonator delete, and Magnaflow mufflers. I've kept up on the maintenance, and my goal is an additional 20-30 HP, and a couple tenths off my 1/4 mi. I'm pretty sure the next step is headers, Will said I'd be good to pulley down after that. I just want to make sure I'm not forgetting anything.
Also, I have a lot of drone with my mufflers; can anyone recommend a good way to reduce drone without it sounding totally mellow? I just want to quiet it down some, especially if I'm going to put headers on. Thanks in advance for any helpful advice.
