Jakegday
'97's and some '98's had the double bent stock air box...if he would have upgraded to a '99+ stock box and gutted it for free...it would have been way better.
ah, thank you
...ahhhhh!
what is your peoples need for low intake temperatures? you dont need them! i ran an open cone on my car from the beginning. i guarantee under any conditions that an open cone will make more power than any other intake.
wouldnt it get too much heat soak with the exhaust crossover right there? or is this only advised if you have headers with ceramic coating?
no crap, but how are you going to produce lower than ambient temperatures? it just doesnt happen. therefore, my 120* IAT still produce as much power as someone running completely ambient at 80* because of the timing tables and how much the blower negates the intake temperature just by heating it up anyway. was my car a monster on a 3.4 pulley in winter? yes. did it feel more like a dog when it was 80* outside in summer? yes. you cannot control weather, so do yourself a favor and make an intake that FLOWS well. the intake temperatures just do not matter that much. i will argue this up and down for weeks.
once moving, the open cone gets close to ambandent temps. its only when your stoped for a bit that they start to rise. once back up to speed there back down to ambandent.
get a quicker refresh rate IAT sensor and you wont have that problem when youre taking off from the line because it will cool down faster.
contact brian (reptile). he has been hand making them.
you will simple replace the sensor in the tb. nothing will change set up wise
no i mean by putting the filter directly on the tbody, maybe the pcm/intake box can stay, the filter i have is only like 5-6in long.
