I just got a 2005 GP and it did have a few minor issues.
First, it got the classic blower that won't blow problem. Easy fix, just got to wait for the part to show up.
Second, the key FOB does not work. I replaced the battery and checked that the clip is firmly soldered on (why are those clips easy to break?) but it still won't lock/unlock, open trunk, or panic at all. Is there a way to tell if it's working and needs to be reset or if I need to replace the whole thing?
Third: the LCD on the radio/CD player is very hard to read. It looks like maybe the LED backlighting either got loose and isn't getting power or the LED burned out. Can that be fixed? I have 20 years electronics experience, just prefer not to spend a lot of time taking it apart if it's not easy.
Fourth: a piece seems to be missing from the console under the key slot and next to volume knob:
http://i256.photobucket.com/albums/hh198/puddle_jump/IMG_9301_zps0f9bd507.jpg
:th_scratchhead: What is it? So that I can look it up and get it to cover the unsightly holes.
And lastly, I'd need manual for this car. Is there a PDF I can download somewhere? I tried Google and keep getting web site that wants to charge an arm and a leg just to view it :th_shakinghead1: Or is the manual not free? I need the manual to find out what else needs to be checked like the fuses, where are the important parts, etc.
The other LCD display is showing today is Thursday, Jan 6 :th_tongue2: so I need to change it (hence the manual request), the cruise control will not work at all (bad fuse? again need manual) and I can't find jack should I need to change tire.
TIA for any answer you can provide.
