crazybrownklick
Aren't different lug pattern
I tapped the brackets for mine. A lot safer and not hard to do.
Yep 15/32 is the correct drill size. I set mine up on a milling machine and did the work.
opss sorry lol did not see that sneaking this in at work between bosses passes lolI told you what tap you need lol
M14x2
Or, you can mail them to me and ill do the work, then mail them back.
the spacers are hardened steel bearings. i see nothing wrong with using them at all. got em on my car, no problems.
Don't use the spacers to do it... Lemme rephrase that..
You can use the spacers, but I wouldn't trust that one bit.
Ok they say for the rears we can use 2004 GXP's on a 97-03 its a direct bolt on is that the only year or is it 04+?
pretty sure the 04 and up use a e brake in the caliper, not the drum in the rotor like the 97-03 and it is convertible to the newer style.
You can't use the rotors from a camaro, you need to use monte or impala rotors
Wrong
You use the 06+ impala rotors with 06* impala calipers.
That's due to the change in the bracket and the design of the hat on the rotor
Aren't the Camaro rotors 5x120 and ours 5x 115
http://www.grandprixforums.net/big-bad-brake-thread-39174.html
/end thread
you can use either 04+ rotors or f-body rotors. they both fit fine with f-body calipers.
Drunkie would you recommend rebuilding the calipers if we get them from the jy or if they lok like they are not leaking just clean them up and throw them on and anyone got a how to on rebuilding a F body caliper?
