Fbody brake swap questions...
I tapped the brackets for mine. A lot safer and not hard to do.[/QUOTE]
If ya don't mind would you explain how to do it?
Do I just smooth out the threads and run a tap through? Do I Drill the hole to size then run a tap through? Is there a reason why you and just bring the bracket and caliper to home depot and find a bolt to fit?
Thanks
Plenty of people have had issues with the spacer method. While many have not, many have.
Drilling and tapping the brackets is easy to do and in many views, safer to do.
Funny. I can't see anyone having issues or reporting issues, ever
And no. The 06+ impala calipers need 06+ impala rotors.
Thanks[/QUOTE]
You need to use a 15/32 drill I believe... I forget exactly. I can look it up though. Then tap them with an m14x2 tap.
You just use your stock bracket bolts from your stock setup.
Yep 15/32 is the correct drill size. I set mine up on a milling machine and did the work.
Thanks hmm don't have a milling machine guess I will just have to put it in a jig and be real careful or see if I know someone with a drill press, and do you know what size tap I need, thanks again
the spacers are hardened steel bearings. i see nothing wrong with using them at all. got em on my car, no problems.
Correct, in fact these spacer bushings are a common practice across the car community, alot of people use them. In fact I'm using them AGAIN for my new setup design I just came up with for another Car.
Don't use the spacers to do it... Lemme rephrase that..
You can use the spacers, but I wouldn't trust that one bit.
I've had my bushings in place for next to 3 years, first the Corvette brakes and now the CTS-Vs; with the close tolerances with the CTS-V setup (caliper to rotor clearances), the spacer bushings are rock solid; even after 3 years of abuse on the bushing.
Ok they say for the rears we can use 2004 GXP's on a 97-03 its a direct bolt on is that the only year or is it 04+?
Correct, 97-03's use an ebrake in the hub, 04+ GP's have the e-brake in the caliper, the only time the switch back occurred was with the GXP's
pretty sure the 04 and up use a e brake in the caliper, not the drum in the rotor like the 97-03 and it is convertible to the newer style.
Correct, you need the rear knuckle, bearing and e-brake setup off a GXP for the 04+ conversion.
You can't use the rotors from a camaro, you need to use monte or impala rotors
Use F-body calipers with F-body rotors; 06+ Monte/Impala calipers and rotors.
Wrong
You use the 06+ impala rotors with 06* impala calipers.
That's due to the change in the bracket and the design of the hat on the rotor
Correct, the 06+ Monte/Impala rotors are also thinner by 1/10"
Aren't the Camaro rotors 5x120 and ours 5x 115
Yes, but the 98-02 Camaro rotors holes are enlarged to fit both bolt patterns of 5x120 and 5x115
http://www.grandprixforums.net/big-bad-brake-thread-39174.html
/end thread
you can use either 04+ rotors or f-body rotors. they both fit fine with f-body calipers.
Actually I need to remove 04+ rotors, you should only use F-Body rotors, there is just a slight size difference (see images below)
Correct and the tap is 14x2
Comparison of rotors
04+ Grand Prix
98-02 F-body rotors
06+ Monte/Impala (posted respectively)
303mm = 11.92"
52mm = 2.04"
30.1mm = 1.18"
28.6mm = 1.12"
70.7mm = 2.78"
14.2mm = 0.55"
98-02 F-body brake upgrade
F-body calipers
F-body Rotors
F-body Pads
F-body banjo bolts
Either drill and tap the caliper brackets to fit or use the bushing spacers, both ways are safe.
Drill and Tap allows you to use the GP caliper bracket bolts, bushings allow you to use the F-body caliper bracket bolts.
ok Drunkie, for simple idiot understanding.. If I source all the parts from say a 2000 Camaro, that will work right? all this talk about GXP this and 04 monte that has me lost as hell...
I ask as last time I walked through my local Boneyard there were about 4 Camaros that had the complete front brakes stil there. I would get new rotors from the local parts store thoug, but the rest... 1998 up camaro will work?
Drunkie would you recommend rebuilding the calipers if we get them from the jy or if they lok like they are not leaking just clean them up and throw them on and anyone got a how to on rebuilding a F body caliper?
