LOL at Nick.. you guys guess which one. :th_biggrin2:
On the sway, is the point in the center pointing down? If not.. flip the bar. Do you physically hear any odd/loud/unknown noises coming from the engine bay when driving or revving etc? There's very little the PCM is going to see as knock that isn't from a cylinder. Especially since it learns noise levels to base knock off of. Did Paul give you any more insight as to his thoughts on it? Maybe a chipped piston causing a hot spot etc?
One more thing. Hop under the car and look at your knock sensors. I've seen a few that got hit by something and the connector going into the sensor was not straight, the connector going into the sensor was broken where it meets the metal of the sensor. This can cause what you are experiencing w/o a doubt.
So, what mods?
3.4" seems a smidge small for that, considering that equates to a 3.2"~ on a GenIII.
I also don't think rockers net that much of a gain...
I'd rather try a larger pulley and see if it helps.
it had the kr before i took it to prj, thats why i took it to him, also i need the pk3 crap taken out of my tune cause it was shutting off my fp.
can you elaborate on the tcc because i was very confused
