Erics00LS
They are: but look up the rotor specs, the stud hole is oversized to accommodate both bolt patterns.
That's crazy, I never knew that! So in theory, I could order performance camaro rotors and they will fit?
You must not hang out on ls1tech "THAT" much then.. lol..
They junt the stock rotors if they want to auto X
and yes I know C5 calipers will work in f-body brackets. I will be running some soon. But you cant use the C5 13" rotors.
The 12" will indeed work with the C5's though, right?
Oh.. and I know 16" fit over the fbody calipers, but can that also be said about the C5 calipers? I use my stockers in winter.
The fins do need to be grinded down for regal GS wheels
Which ones, I put the chromies on and never had to grind.
