    TIPS:
Evap canister hose
94grandprix
Has anybody got a non dry rotted vacuum line that goes from the side of the canister to the intake,mine was dry and broke,here's what the line goes to on the left side in case that's not what it's called uploadfromtaptalk1411943814923.jpg
go to a parts store, they sell vac line for a buck a foot.
if you need the fat line off the TB that then gets thinner to the evap, you buy a fat 5 inches of hose, then push the smaller line inside the fat line.
like this.
The whole thing broke,first the canister hose connector did,then while removing it the hose so regardless I need his canister
its all still hooked up, but the codes are deleted. i get a cas cap code p0440 iirc. could never find a leak, and the gas cap was not the problem. so they got deleted.
same with my egr, its all deleted, but still there working like normal.
