Ease of installation of a PLOG
You mean one of the two 15mm that hold the doggie between the rad support mount and the engine? If so.. turn the other way next time. I've never seen someone break one of those.
Better yet.. Stop now.
Right Lol. I got the cross over bolts off like butter then the next thing I know I break the damn dog bone bolt.
Sent from my PantechP8010 using Tapatalk
ok... im seriously not trying to dick it up right now.
I have never in my life heard of a db bolt being broken.....
I thought it was just jammed and I started turning it harder with the breaker and, poof! The bolt breaks and flies off. I was effin pissed man Lol
You might want to do this while the head is slightly warm, dont break a manifold bolt in the head
Heat won't matter if he's righty loosey, lefty tightying things.
Trick for you. Hold your ratchet in front of you.. with your hand on the socket, turn it to ensure it's moving in the correct direction. Doesn't matter if you are upside down and backwards working on a car. If you do that. You should never be able to "reverse loosen" a bolt.
