E85 on 2005 gtp
This is the last I'll say on E 85. I was trying to be a good member here and lend my years of experience on the matter. I wasn't telling anyone NOT to go E 85 just do some research.
[h=2]Corrosive[/h]
  • Ethanol corrodes a number of materials, including plastic, fiberglass and other parts of the engine. Corrosion will either contaminate the fuel or destroy parts of the engine, such as the fuel line. However, this doesn't apply to cars that are designed to run on E85. These vehicles are built with materials that ethanol won't corrode. That being said, it's a factor to consider if you plan to convert your own vehicle to E85. To complete the conversion process, you'll need to replace any plastic or rubber engine parts, such as seals and hose lines, that the E85 comes into contact with. Many of the seals you'll need to replace are part of the engine block itself, making the conversion both difficult and expensive.
Read more: http://www.ehow.com/info_8109728_problems-e85-fuel.html#ixzz2qDHDWu5A
To the guy who says E85 ruins your motor I beg to differ. Frosty and I have been running it for a year and a half now, making many 300+ mile trips. I recently had my motor apart for some work and it looked the same as the first time I ripped it apart. Our motors love e85 + boost. Also e85 cleans carbon build up and just generally is safer for modding a car. Do it if you can. I ran the stock pump and 60# inj. until I got down to a 3.0 pulley when I needed a pump. I got the AEM e85 fuel pump. Show some hard evidence of it ruining a motor and then you can claim that it isnt safe.
Hey decker was that fuel pump plug and play and what re wire kit you use
Sent from my SGH-T999N using Tapatalk
AEM E85 pump from ZZP, I went turbo and havent put the pump in yet but it should be mostly plug and play. I have the kit from intense.
E85 is tits I'm still making timing tweaks don't get some mileage back and edit some transient tables by overall the **** performs great
