Doug 97 gtp
I have a really loud clunk on the driver's side front i think. i replaced the hub bearing the cv axle strut mounts sway bar to chassis mounts and sway bar links i have inspected my car tightened everything up and it still makes this noise. It makes the noise turning left at full lock and sometimes going straight in the morning if i get on the gas a little bit and it also does it in reverse if you give it enough gas to make the car move. its made this noise since i went down the drag strip i cant find out what this noise is i have replaced the motor and trans mount and all of the a arm bushings are fine the springs are not moving nor is the struts. I am completely mind boggled on what this could be. I have read up on similar problems and i cant find anything to help me. any help would be greatly appreciated. the noise is driving me crazy and i know someone has the same problem that i do. the noise happens when im in drive and when reverse and when i turn either way in drive or reverse. i have no idea what it is
