156ft lbs.
AllData shows 159 ft lb's. I used a 36mm socket to remove mine when I changed the bearings.
| [TABLE="align: center"] [TR] [TD]Front Wheel Drive Shaft Nut (New) | 118 ft.lb |
Nope, look again.
Search "axle nut" on alldata.
[/TD]
[TR]
[TD]Front Wheel Drive Shaft Nut (New)118 ft.lb
[/TR]
[/TABLE]
Lol. It's 159 ft lbs in My version of Alldata too.
| Front Drive Shaft Nut | 160 N.m (118 lb ft) |
Ok.Nope, look again.
Like this?Search "axle nut" on alldata.
[/TD]
[TR]
[/TR]
[/TABLE]
Do as you wish, but 118 ft lbs is not enough for that nut.Maybe in your head it is.
But the REAL torque spec per GM is 118 ft lbs.
Any other number than 118 is wrong.
