Honestly after trying every part on a W body short of lateral links and coilovers, I'd have to rate the front bar as the #1 improvement in handling. It helps control all of that weight out front.
Next was bilstein HD/vogtland up front.
Next was trailing arms, followed by rear sway (ADDCO bar, 22mm solid)/bilstein HD/vogtlands, with STB's in dead last. And by dead last I mean basically worthless with all of those other components.
Arguably, I didn't notice much difference with the rear struts/springs/sway. The rear end still had way too much play on high speed sweepers. That's not to say it didn't help, it surely made a difference, but after you consider springs were $150, struts $600, sway $200. Probably would have been better off buying the BMR rear end link kit.
All depends what you're after. With all of that done, you could feel every little bump in the road. However the ride wasn't uncomfortable. Firm but smooth, the bilstein way.
Oh and I did all of this on 225/60R16. Enough tire to smooth out the bumps, yet still competent enough to provide a solid enough steering feel given the obvious heavy front end. Driven cars with 1" sidewalls, interesting, but not for a daily.
