450 Front 250 Rear
No they are not bouncy...they ride similar to stock but a bit stiffer...springs rate is what was on the add...any other info I don't know other then how they rideIf they are, you must be bouncing all over the place.
What is the open height and height at ride level.
Yeah I agree with you on that one...I don't know what the stock spring rates but these are similar in ride quality just a touch stiffer...stock my suspension was already pretty stiff though...I do know that I had to compress them a decent amount to get the tophats onThen they're probably closer to 200/140 or less.
Didn't you have trouble with agx's? Which are supposedly the best strut for lowering?
Lol......
lolololol stock suspension was pretty stiff. you havent seen a stiff spring if you say dna's are stiff.
and vet, my used agx work fine.
Yes my Comp G suspension was pretty firm stock yes the DNA springs are stiffer then the stocks yes I have had alot stiffer suspension setups on my subaru yes I know what a stiff spring rides like...
Nope because I have no clue what Im talking aboutam i supposed to be impressed now?
I agree...on my stock comp g struts they work fine...if u want something really stiff get struts you can adjust and a spring to compliment themi could see these being a useful option if youre just dropping on stock struts. if you're doing a rebuild with something more performance oriented i would definitely sway to something more proven with spring rates that are better suited for the application.
