digital boost gauge
00Daytona
I'm assuming the boost gauges that come in the dic max out at Whatever psi, and my car has a 3.4 pully so it max's out at half throttle, now that dosent mean I'm at like max for that pully correct? I'm guessing the ones in the gp's are more of a light show?
umm stock gauge is set for like 6ish PSI with a 3.4 you are prbly around the 9 to 10 PSI mark... so at about half throttle it will go full cause u are registering the 6ish PSI of boost
my regal will show over 8 psi, bone stock only if its like 5 deg's or less outside ill see 8.5. in warm weather i see 6.5 to 7 tops at the shift points. one day ill find out if it reads higher.
but then again i dont know when the last time i even looked at my boost gauge lol if you hear it whine, your boosting.
them lego blocks seem to be worthless anyway. the regal gets a true digital read out, the sports car gets a dummy lego blocks display, way to go GM!
