differences in superchargers really need help!
GTPMidknight
I bought a 2001 gtp supercharger that was ported for my 1997... well there is no vacuum solenoid on it is this a big problem will the car even run?
I can for sure text you one the solenoid can still bolt on the thing that goes into the m90 can no longer be bolted in the holes are filled and the spring on the lever is removed.
you run 98 vac line routing. google it.
only 97 had that vac tree on the blower, car will run with out it change the way the lines run, thats all.
the bbv maybe f'ed up and needs to be replaced.
host your pics on photo bucket, then link them here. so we all can see em.
wait someone filled the boost bypass valve bolt holes and the actuator arm?
sounds like it may have been used as an (empty) turbo intake setup...
^ 97 blower vacuum line routing.
^ 98+ blower vacuum line routing.
^ Is this what is missing? The Boost Bypass Actuator? Are you saying where this actuator arm goes into thw supercharger housing is blocked off?
