how do I know what ohm resistors to get? or do they come with the LEDs? I'm too lazy to drive to radio shack :th_laugh-lol3:
I found that if you dont set the LED into the unit, but keep them back a bit the beams will overlap and will come out even
I honestly believe that 560 ohm resistors do not exist in Canada...well at least Windsor..I jumped the boarder to Detroit the other day to hit up AutoZone and Radio Shack...they had the LEDs but no 560 resistors... and that city is way too shady for me to be driving aimlessly around to other Radio Shacks. Called stores around here...NOTHING. ....brutal.
Hell on Earth.... they're even sold out on the Internet.
560 ohm 1/2W 5% Carbon Film Resistor pk/5 - RadioShack.com
lmfao, must be my awesome thread selling out the nation....
I changed mine to blue and they were working for like 5 min then the light shut off, any ideas? Is there some kind of fuse just for the back lights? The traction and button lights are still working. looked awesome while it lasted, im going to get new leds tomorrow see if i burned them out but i kind of doubt it cause i wired them in with the resisters. thanks
i used the 4 pin blue part#276-0023 and 560 ohm 1/2watt 5% tolerance resistors part #271-1116. when i put them in i had one of the resistors bypassed by some sloppy soldering but the other 2 were working so i took it apart again thats when i noticed the resistor bypassed so i re soldered everything and the same two worked for a few minutes then went off.
im deff going to try new leds tomorrow. when they were onn seemed kind of dim also if that has anything to do with it idont know. at least my soldering got way better from taking this thing apart and putting it back together so many times lol
got it leds were burned out. any idea why the dic dimmer is reversed from the rest of the dash? when i go brighter the dic gets dimmer and vice versa. i also couldn't find a jewel cd case so i used a piece cut out of a blue bottle of dawn i think its a little to dark so i might try to find something that lets more light through later
