Delilah....dyno rackar
Re: Her names Delilah......wobble wobble wobble
you have the DoD tuned out right? i got my low oil warning on my DIC on Friday at about 40% oil life left......
No I don't have DoD tuned out. And I never let my oil get below 50% life left and this past time it was at 61% and I had driven 3123 miles.
New goodies....80 amp relay for my HID's cause my 55watt ballasts keep blowing the 30amp one. And a new key fob...all the internals and everything for 20 bucks. But I just need it to repair mine
Also checked all my fluid levels today and
Oil level = Perfect
ATF level = right on low mark (1.5q added)
Brake level = Perfect
Coolant = Perfect
PS Fluid = Perfect
My old key fob wouldn't work....and I was to lazy to buy aluminum foil to fix it. Eventually I'll fix it and have it programmed then I shall have two fobs
whoa whoa whoa your to lazy to get foil but not to lazy to get an 80A relay?????? i dont get it
Yea....all that stuff was ordered online. I just had to go down road to post office instead of all the way out to town
Yea but screw buying their ****. Its all expensive for stuff like that. I go to town once a week....Sundays
i'm over 3k right now on this oil change.....
GM says 1 quart per 1500 miles is normal-ish, so being down almost 2 quarts at 3k is pretty normal.
Oil level = Perfect
Coolant = Perfect
PS Fluid = Perfect
Quarts????????
And the trans was at full op temp?
I'm pretty sure the dipstick says add pints, you may have just over filled it by alot.
