i refuse to like that codethere a guy on here told me to do this
$5 o2 cheater/non fouler how-to - evolutionm.net
01+ goes into a CAT diagnostic when the rear 02 is deleted by code. It will sometimes cause the LTFT's to fluctuate back and forth and may cause the car to surge, it is testing the CAT. The only way to disable this is to run an 02 emulator or install the rear 02 so it is not directly in the exhaust stream or disable this diagnostic using a program called tiny tuner.
It doesn't run this test at all times, just when it feels the need to run this test, then goes back to normal.
That explains my surge issues,thank you so much. Will have the tune modified,seriously I thank you.
How often and how much did your car surge though? I ask that because most times this test is ran, not too many people notice or realize their ltfts are fluctuating, unless you are scanning or keeping a constant eye on it.
Not really anything else to add, there are a lot of things that may cause a car to surge, disabling this test using tiny tuner may help some, not at all or help a lot... lol
Front 02 codes are common with homemade extensions. I say if you're going to run headers, get a bung or 2 welded in the crossover near the rear head. Then you don't need an extension, won't worry about water, don't have to worry about it hitting the firewall and it's easy to replace, as well as having an extra bung for a wideband if needed. The other problem at times is the tune, tune with a wideband and make sure your fuel is close to commanded afr. If you own a tuner and wideband, try running open loop getting a couple tunes for different times of the year and ditch the front 02.
Usually if the front 02 is really dead, it will stay at 435v or so, just steady.
