SilverCompG
Well, I was hoping my first post was gonna be more upbeat after lurking for a while. I just bought a 2004 Comp G with 154k on an impulse. No records at all and lacking maintenance but I thought it could all be fixed easily. Trans was feeling worn out so I did a pan drop. Fluid started coming out and I was immediately concerned. It was as black as oil in the catch pan. It didn't look that bad on the dipstick. I had a 10 quart pan and it completely filled it up which didn't make sense. Everything I read said it should have been around 8 at best. Cleaned it all up put the new filter back on. The pan had no shavings other than on the magnet. Put 2 jugs of Max Life dexron VI back in which filled it up even though that's less than what came out. Drove great for 2 days then came today. Was pushing pretty hard in 2nd gear and it made a loud bang that felt like something broke. Limped it the rest of way to work but could feel tranny slipping. So now it has reverse but putting it in drive does nothing. Might as well be neutral. If I use the tapshift it will go in 1st but slip pretty bad taking off. So I've resorted to manually taking off in 2nd which helps but it feels like its gonna die soon also. 2-3 shift is horrible and 3-4 is fine. So I'm guessing its toast right? I've been sick all day since it happened. Anybody want a 2004 Comp G?
