NaturallySmashed
Hey everyone,
My car has always had an intermittent problem with starting. Sometimes it will start normal and sometimes I have to gas it for 5+ seconds to keep it running. It seems to be happening when the engine is cold, when the engine is warm this problem rarely happens.
I have cleaned the throttle body, changed plugs and wires, cleaned IAC valve, cleaned MAF, fresh filter, and pcv valve. I do not have vacuum leaks.
I'm thinking even thought I have no DTC's I should replace the IAC valve. Should that be the next step?
Thanks in advance.
Thanks in advance.
