2000gprixgt
will the cobra r rims fit on a 2000 gt? thanks
are you referring to real cobra r's or aftermarket ones? either way theyre not staggered. real ones would be 17x8s and aftermarket are usually 17x9
Well then, the 17x8's should be ok, but the 17x9 will probably have rubbing issues w/o other work and or spacers
do you run cobra rims that you know this? 17x9 is fine, even with the +24mm offset ones. therefore, you are wrong.
you can do it. i have faith in you.
