    TIPS:
Classy's Retrofits LLC 1997-2008 Grand Prix Retrofits - LOOK INSIDE
Re: **97-08 Retrofits** GROUP BUY! Thats right, I said it!
On the group buy does the 20% off apply to the whole order? Also if I buy the hid kit through you and I have an issue. Would you then be who I deal with on that or would it be trs? Asking as I've had bad luck in the past with several sets of xentec and ddm ballasts and bulbs.
I installed my retrofit headlights with the harness from TRS last night and when I turn the car on the high beams come on, when I actuate the lever to turn on the high beams it switches to low beams. I think the blue and brown wires are backwards on the input from the car box. I know I read that someone else had this problem, but I cant remember where. Is it worth the hassle to switch the wires, or should I contact TRS for a solution?
If your 97-03 you gotta re pin the connector to 9007 as its wired for 9004 TRS should show you what wires to move where.
Sent from BFE
I know this is a longshot, do you make retros for an 01 sunfire and whats the pricing?
what is the install process for the 04-08 retrofits housings? something needs to be cut behind the housings in order for them to fit?
Probably better to ask in the correct forum and start a new thread, rather than the guys for sale thread.
Re: Everything for $1400: 04+ Retrofits, SPO, Nitrous kit, Turbo, Fog Lights
Hi I really need the passenger side rocker covers and have had no luck getting or finding them they are always gone can you find a set or make them?
Need a new set of headlights and I really hope classy still makes these. I refuse to go back to stock junk
Contact them on facebook. They changed their name. I believe they sold the business. I had black bird lighting solutions make me a set. You can go to the last page of the link in my sig to see how they look. Quality work from them.
