Clark's GTP "WHINER" LOWERED ON COILS 18X9.5'S
Re: Clark's 2002 gtp
bump....
Don't own them, however: No boots for struts, no bump stops, no "good" strut options unless you do it all yourself, adjusters/sleeves can become damaged from a build up of road salt if not cleaned regularly, some recently are complaining about the spring rate, top mounts aren't camber plates.
Quite a bit was overlooked for 1500.
But quality struts: 1000, revalving struts: 300, 2-3 hours of shop time at 65 an hour to shorten: 130-195, camber plates: 600+, springs/sleeves etc: 500-1000.
Running total? 2530-3095. Thats to "do it right". Might as well go air at that price point if you're all about going low.
And they'd still be non adjustable, however they'd be valved properly for your spring rate, expected use and corner weights.
Well like I said earlier in the thread I did want some functionality aswell as low. But yea I bought these along time ago before many people had written about them and didn't have anything to go by. And they are really the only coilovers that come per assembled for the w-body
pretty much all of what Matt5112 said is what I had a problem with. I thought the spring rates were especially troublesome. The default rates are so soft that when I lowered it about 2 inches i was bottoming out everywhere and the room left for adjustment just kinda had me wondering why 325/275 is default. And I was talking about it in my thread a little bit, but using stock length struts that just lose travel when adjusted down didn't seem too great.
A mods list
Mods
-Ceramic coated Zzp headers
-Catless downpipe
-3" zzp catback magnaflow resonator
-flow pro straight through mufflers
-Xp cam
-105 valve springs
-Custom tuned PCM
-40lb injectors
-Home made intake
-3.2 pulley
-Autolight 104 plugs
-Zzp coil packs
-Zzp plug wires
-Poly engine mount
-Poly Trans mount
-Poly dog bone mounts
-Poly motor mounts
-Shorter dog bone engine mounts
-Ported gen 3 s/c
-Ported throttle body
-All new gaskets
-180 Tstat
-Strut bar
-Diagonal bars
-Trailing arms
-Polished valve covers
-Polished fuel rails
-Billet aluminum oil cap
-Black s/c
-A pillar gauge pod
-AEM Air fuel
-2 auto force scan gauges
-Kyb agx coil overs
-18x9.5 enkei rajin rims
-GM performance sway bars
-Roof rails
-40th spoiler
-04+ seats
-Black bumper accents
Clear corners
-Hid's
-LED interior lighting
-Debadged
-Shaved shaved key hole
-alpine deck
-2 gauge wiring
-800watt Boston mono amp
-2 12' Boston G5 subs
-bassworx box
-2 way Command start
And I have most definatly forgotten some stuff
Damn...why does everyone have to make my SSC lowered car look like a 4x4 these days? :(
On Topic- that is a sexy car bro. Way to rep the CA as well! Love it! 5*
I got them off 1010tire.ca (a Canadian website) so I didn't have to pay shipping charges there was a deal on them when I got them but I think you can grab a set for under 2k
This as is low as I can go on this spring rate.... It's literally not drive able.... That's why I got stiffer springs 👍hahah next spring I will repost lower pics
Haha I was Jking lol as low as my car is and its not even close to as low as yours i cant drive over speed bumps or pull out of big slants with out takeing my bumper off lol!
