rob, pm me when ya can about the top ring gap
I'm waiting on a response from Morad,last time I checked they had a 150kmile block but no pistons/rods. Are those TRW's a direct fit? You said they are for a GN?
I have my ex convinced I can make the car reliable,so she'll keep it now. So, I'm seriously looking guys.
I have 6 pistons/rods coming from Morad from a L67 motor. Hopefully this coming week I'll be able to get a quote on bearings,gaskets etc heavily discounted.Yeah, they are a direct fit. GN is still a 3.8, so same bore. Just compression will be a little less, I think. But a cheaper way out if you want.
If I were in your shoes, I would just stick with the ones from Ed though.
It doesn't show up,I'm not a member.
Anyways Where is everyone getting there gaskets from? I was gonna get the complete engine kit from ZZP I need everything gaskets,rings,bearings,etc. Any suggestions on reassembly? Things I should be keeping an eye out for?
how would you know if you had this problem?
smashed plugs are usually the best giveaway. the next giveaway is burning oil. the next would be when you take your heads off and see part of the piston missing.
leave everything alone and put it together. carbon on the pistons gets you more compression.
:th_doh:I should have known better. Supercharger is being left alone.the rotors in the S/C are what I was referring to.
