Abrasive
I say it with pictures
its you nuetral safety switch. disconnect it and the car will be fine. the only thing its affects is the light in the gaugu cluster that tells you the gear your in, and the doors unlocking when you put it in park. everything else stays the same
The nuetral safety switch is located under the shifter and only keeps you from taking your car out of park unless the key is in the on position and your foot is on the brake. It has nothing to do with not being able to remove the key from the ignition. The problem is the Park Lock Solenoid behind the ignition.
And GrandPrixlbc, if you're genuinely concerned about your passenger reaching over and removing the keys while you're driving.... then you should seriously reconsider who you let in your car in the first place. :th_winking:
