Old info, but gives you the idea of power made...
----- M90's -----
***All blowers are considered gen 3 m90's unless noted otherwise
ZZP's Comp Cam XPZ grind:
1. Scott Kleis w/ 425WHP (I/C, G5 m-90, ZZP Alum Heads, 9:5:1) [STD]
2. Fred Cakanic w/ 421WHP (I/C, G5 m-90, ZZP S3 Heads, 9.5:1) [STD]
3. Zooomer w/ 413WHP (I/C, G5 m-90, ZZP S4 Heads, 9.5:1) [STD]
4. ALancour w/ 400WHP (I/C, G5 m-90, ZZP Alum Heads 10:1) [SAE / Mustang Dyno]
5. House w/ 393WHP (non-I/C, G5 m-90, ZZP S4 Alum Heads, 1.7 rockers)
Stattama's Comp Cam NIC Grind:
1. House w/ 359WHP (non-I/C, ZZP S3 Heads)
2. raflyer w/ 330WHP (G5 m-90, non-I/C, stock heads)
Intense's Cam Motion Stage 4 Grind:
1. Tim King w/ 411WHP (G5 m-90, IS3 Heads, I/C) [STD]
2. Tom Smith w/ 354WHP (I/C, IS3 Heads) [STD]
Intense's Cam Motion Stage 3 Grind:
1. Ted Quartana w/ 399WHP (G5 m-90, IS3 Heads, I/C)
2. rsilva w/ 366WHP (G5 m-90, IS3 heads, I/C)
3. Intense 97 GTP w/ 355WHP (I/C, IS3 Heads)
4. DonF w/ 351WHP (I/C, IS3 Heads)
5. GTPMorad w/ 349WHP (I/C, IS3 Heads, non-n20)
TEP's R.Lee's Comp Cam Grind:
1. Spyder w/ 352WHP (I/C, custom Heads)
2. Mike Dye w/ 347WHP (I/C, C-Ya Heads, Locked TC)
3. BrentGTP w/ 328WHP (G5 m-90, I/C, custom heads)
4. Das Regal GS w/ 319WHP (non-I/C, custom Heads)
5. Spyder w/ 316WHP (non-I/C, custom Heads)
ZZP's Comp Cam XP Grind:
1. MIGPCPREZ w/ 367WHP (G5-m90, I/C, 1.7, ZZP S3 Heads)
2. John C w/ 361WHP (I/C, custom heads) SAE
3. Adam_Murphy w/ 360WHP (G5-m90, I/C, stock heads, 9.5:1) STD
3. GTXPrix w/ 350WHP (I/C, IS3 Heads)
4. jamhoney w/ 347WHP (G5 m-90, I/C, stock heads)
5. phat_gtp7 w/ 346WHP (G5 m-90, I/C, stock heads) STD
PRJ's Comp Cam LL Grind:
1. Eric Wolfe w/ 349WHP (G5-m90, I/C, 1.8 Rockers, stock heads)
2. Big Fire w/ 331.8WHP (I/C, 1.8 Rockers) STP
3. indy99gpgt w/ 303WHP SAE
Grand Prix Store's Comp Cam HL Grind:
1. Matt Swartz w/ 308WHP
2. Mr. Hat w/ 307 WHP (I/C, stock heads)
3. Jon B. @ TOG w/ 300WHP
4. GN w/ 275WHP
5. reidonly w/ 251WHP
Intense's Cam Motion Stage 2 Grind:
1. streetrace w/ 334WHP (I/C, THR Heads)
2. Ramairfreak98ss w/333whp (I/C, custom heads/stock valves)
3. Allowencer w/ 313WHP (I/C, IS2 Heads) [SAE]
4. 97 GPGT w/ 303WHP
5. Gorillakong w/ 299WHP (Custom Heads)
Intense's Cam Motion Stage 1x Grind:
1. Tim King w/ 395WHP (S4 Heads, I/C, G5-m90) [STD]
2. Rogue w/ 372WHP (G5/3-m90 proto, IS3 heads, I/C, 1.8 Rockers) [STD]
3. RaFlyer w/ 335WHP (G5-m90, stock heads, non-I/C)
4. GTPRedfire w/ 328WHP (non-I/C, G5-m90, stock heads) [STD]
5. Her GTX w/ 324WHP (I/C, stock heads) [STD]
Intense's Cam Motion Stage 1 Grind:
1. Bruce Ley's w/ 296WHP
2. Alex1000 w/ 292WHP (I/C, stock heads)
3. syclonewillie w/ 275WHP (I/C, 1.75 rockers)
4. supersilvergtp99 w/ 258WHP
5. Scott Burnham w/ 249WHP (non-I/C, stock heads, 1.75 rockers)
ZZP's Comp Cam VS Grind:
1. roasted w/ 356WHP (I/C, G5 m-90, 9.5:1)
2. Bill Hooper w/ 341WHP (I/C, ZZP S3 heads)
3. Zooomer w/ 340WHP (I/C, ZZP proto1 heads)
4. autogary w/ 337 WHP (non-I/C, IS3 heads)
5. Intense 97 GTP w/ 321WHP
3800Performance's Comp Cam GTP Grind:
1. 2MCHPSI w/ 323WHP (I/C, stock heads) [SAE]
Grand Prix Store Comp Cam GTP #1 Grind:
1. Spyder w/ 287WHP
2. Acb1450 w/ 279WHP
3. Jet w/ 260WHP
4. DarkObsession w/ 255WHP
Stock Cam:
1. DJ Whiz w/ 317WHP (I/C, stock heads, 1.9 rockers, 8.5:1 CR) [STD]
2. 40thGTP w/ 315WHP (I/C, stock heads, 1.9 rockers)
3. Bronzo23 w/ 303WHP (I/C, stock heads, 1.9 rockers) [SAE]
4. John C w/ 295WHP (non-I/C, stock heads, 1.9 rockers)
5. Ron Vogal w/ 293WHP [Mustang Dyno] (stock heads, 1.9, I/C, E85)
