Built 4t65e - The results are in.
Re: Fall transmission build - Has begun!
Got some of the stuff today.
Shown:
Master kit w/ pistons
Bushing kit
Washer kit
Stater support bearing
Lube dam
Filter
Magnets
Bob made a good point on the bushings. For $27, I went for it. Just need to figure out how to get them all in...
Hey Bill, don't leave me hanging!!
No ONE reason in particular. But here's how I ended up with the 2.93 setup.
1.) It's the standard ratio for the supercharged cars. Whoever buys it won't NEED a tune to use it. (When I eventually sell my car, I'm pulling the built trans and selling it separately)
2.) According to the TEP website, "The 2.93 ratio set is what we suggest and use for all builds making 400+whp and has proven itself to be the most durable."
3.) I don't drive it a ton, but when I do, it's like 75% highway. My mileage already sucks, a lot. I higher ratio would only make that worse.
4.) Availability. I bought them used. It's what the guy had. Honestly, that trumped everything else. :th_winking:
Got the new bushing pushed into the stater support. My hillbilly press worked pretty good. I didn't want to use a hammer and socket.
Very little damage, if any, to the bushing.
Also dissembled, inspected, and reassembled the input/3rd sprag assembly.
So um this rebuild is for me right? I don't care what these other assh0les say your a good dude. HAHA
I'll send you a PM for shipping address once your done.
Money talks. :th_eyebrows:
By the time it's all said and done, it should be pretty close to the Triple Edge. 4T65E-HPS3
Thanks Bob. I'm really taking my time with this one. Pouring over every detail, and researching as much as possible. All the old posts from Trannyman95 (Dave @ TEP) are a gold mine.
Speaking of TEP, looks like I'll be needing an input clutch apply piston from him too. I won't be using this one.
Didn't get much time with it today. Small steps.
Old bearing out.
New bearing in.
Manual shaft and seal in.
And this came in the mail.
I wish I could have done what you are doing. Seems like every time I broke a trans, I had to have it fixed yesterday (my car was a daily for awhile )
I hear you. I hate being in a rush. When it's done, I always feel like I could have done something better. Not this time...
I can get a (mostly) working core from the pick-a-part soooo cheap. It would be silly to try to pull my current trans, rebuild it, and reinstall it in any reasonable amount of time. Plus, by doing it this way, I'll have a working transmission on the shelf as a backup in case anything happens to one of the 3 supercharged w-bodies in the family.
New bushing goodness for sure. Most people skip them because of the difficulty of replacing. On a couple of the ones that I've done I was able to skip them because they were cores that were both below 40k on them.
Re: Fall transmission build - Slow and steady progress
Now that I've done it, I definitely think it's worth the effort.
Got the reluctor wheel mounted to the drive sprocket.
My bonded separator plate came today. $15 shipped on Ebay from a dealership closeout.
Fortunately, it was undamaged in spite of USPS's best efforts to destroy it.
Almost done with the bushings,
Only one left is the driven sprocket support.
Made a trip to the trans shop today to get some more parts
10pc. Input clutch set
And a chain
I probably know where all this stuff goes
More work after a lunch break
Got the final bushing in
I cut a little slot in it to relieve some of the interference
It doesn't get much closer than that
There's two bushings leftover. One for the diffy cover of a non hd unit, and I think the other is for the torque converer
Scuffed/buffed the sealing surface of the 2nd clutch drum
Verified the function of the housing check ball
Assembled the 2nd clutch assembly dry, then checked the clearance. I like it
Now the clutches can soak
