1979 Yamaha XS650
Mileage: unknown
I bought this bike last year partially done and I went over the bike and made it my own. I replaced the seat, tail light, handle bars, and the put an electronic ignition on it because the old points were worn out and it was running max timing all the time. Over the winter I added the levers, speedo, chain tensioner, put a new exhaust on it, got the tank and side covers resprayed the current color and changed the chain and sprockets. The motor and carbs are stock and the plan for next winter was to pull the motor and do a little refresh (XS parts are pretty cheap), but I'll leave that up to the new owner.
It's a super fun bike to ride for semi-short distances. It's not very comfortable, pretty violent on rough roads, and pretty loud. It's a 100% head turner and gets lots of attention. I have probably only put a thousand miles on the bike total since I've owned it. I'm selling because I don't get to ride much anymore with the kid around now and I'd like to put some money into my new car.
Specifics:
- 19" front wheel, 16" rear Harley wheel
- TC Bros weld on hard tail
- gordon scott stacked, curved drag pipes; black DEI heat wrapped
- steel dragon performance velocity stacks
- kick only, no battery
- 7/8" straight bars
- adjustable sport bike levers
- low mount mini speedometer
- leather solo springer seat
- full permenant magnet alternator
- full pamco electronic ignition w/e-advancer
- tail end customs power piston tail light (LED)
- powell peralta chain tensioner
- new 17 tooth front and 30 tooth rear sprockets
- new 530 gold x-ring chain
- fresh oil (rotella t6) and filters
- fresh paint on tank and side covers
Known issues:
- minor oil leak
- new chain rubs rear tire (fix: smaller tire or offset sprockets)
- clutch drags when at running temp, stalls at low idle and difficult to find neutral when running (fix: adjust clutch appropriately [very difficult], constantly adjust clutch cable at lever while riding, or hydraulic clutch conversion)
I will not sell it to you if you're a new rider. This is not a new rider friendly bike. It will hurt you.
$4000 as-is.
Is the ad still up? It's still available.
