Hey guys sorry i haven't replied back....
Thanks for going over on how to test at TDC. Last time did that i could see the pistions and the motor was out of the car so it was a little easier
Verdict- Hg is fine.... It was My CPS not letting it start. Replaced that and she fires up but ran like complete SH%*. I ran compression test/ new leakdown on every cylinder. My front middle has zero compression. So My dads buddy came over with his camera (little snake) . This thing is amazing! He goes down in and makes sure i didn't pop a piston. It all looks good... during the leakdown test we had air coming out of the exhaust (bad valve/retainer) So we are crackin into it this week to get the head out, bring it to a machine shop, put a new valve in (he thinks something just got stuck or i dropped the retainer) then put it back together w/ new HG, and everything new on the way up.
So...... i quess i am happy its not a pistion... The Hg will get replaced anyways.
What i have replaced:
- 1 Coil (was lower than the others during testing and wanted to eliminate it)
- MAF Sensor (had check engine light on for this guy for a month now... hadn't had time and wasnt effecting anything that i could tell.)
- CPS- IT GOT IT RUNNING
-New spark plugs, New wires.
- New serp. belt and new tension pully ( was spun) Bad bearing)
So even tho i spent about 275 in parts... It was all things that needed to be changed..... Now Ill spend another 300 to get the HG kit, heads into a machine shop, new valves etc.... But for just over 500 and this being the only major thing even to go wrong with my car, i am ok with it. This puppy is gonna run great after and for a long time!!!
Thanks guys for all your help. When my stuff breaks it likes to give me a chase. Cant just be a coil and be easy..... HAHAAHH
