I wasn't aware the 6.0l Vortec Max was an LS engine. And I find it strange it only did it with the Royal Purple and not at all since I switched to mobil 1. I would lose a ful litre between oil changes with RP. With the mobil 1 I have yet to see it leave the full line on the dip stick.
I didn't say it was.
In order to increase HP and MPG, GM has been using looser piston rings in some newer engines.
This causes blow-by and oil consumption.
This was (and is) common in the LS2 as GM wanted to claim a 400HP/400lb-ft TQ engine. One trick to loosen the engine up is to have looser piston rings. They use this same trick across their engine line.
My guess is that GM has a TSB or something similar for your engine for standard oil consumption.
The only reason I bring up the LSX engine is that it's famous for oil consumption.
Also - oil can tend to burn more in an AL block as AL has MUCH less heat capacity and will also expand more than a normal cast iron block.
Bottom line: oil consumption for engines is normal. Normal to the point that your engine mfg will specify how much is normal. It's not evaporation.
