MoarkatsINmuhtrailer
i always do penzoil full synthetic 10w-30, with a k&n.
thicker means less oil flow through the already tiny oil passages of the 3800.
I used to use Royal Purple, But noticed it would majically "evaporate". Id lose about a litre between oil changes in my Denali. no leaks, no sweats, nothing. And its not burning oil, as it hasnt done it with any other type of oil. I also noticed alot of bubbling with royal purple. id run my engine for a few minutes, turn it off and check the oil and there would be visible bubles in the oil on the dip stick.
I have switched to Mobil 1 full synthetic and I havent had any of the issues at all. No bubbling, no oil "evaporating" lol.
It was a tough thing for me as I was a huge Royal purple fan. Used it in everything I owned. Unfortunately just over the past year or two I started noticeing things. Does anybody know if there was a formula change or ownership change or something with Royal Purple??
The oil isn't evaporating - it's burning.
This is normal in LS based engines (like in my GTO - GM sent out a bulletin warning me to check the oil level at every gas change). Google oil consumption and you will see what I mean - it's normal for aluminum engines.
My GTO will consume about a quart per 3000 miles. It has an LS2 engine. This is normal - it's burning - you're just not seeing it...
To me, a quart in 3000 miles isn't bad at all. I consider it normal, even if it's a new engine.
Yeah... A quart of oil every 3,000 miles seems like a lot of oil being burnt.
