wowitsfast
once i build it im not planning on taking it back apart but at the same time in not build a ground pounding rocket just want i reliable toy i can pound on from time to time
Update on my car. I just pulled motor out today and pulled oil pan, checked the #6 rod that I took loose when checking motor. The bearings were fine. Started removing 1 by 1 and found #1 rod bearing to be the cause. I have ordered a used engine with 156k miles that I'm gonna put in and drive. While building my original engine. Gonna put diamond pistons,h beam rods, ARP bolts in the entire engine. Intense stage 3 cam and heads, smaller pulley intercooler, and new trans to hold power. Will be about 2 years in the making but I want 450-500 whp
my guess is 500+ most turbos are on stock bottom ends.
