pro ratchet,
what about the hurst styled one?
You talking about the Hurst quarter stick? I might be able to put one of those in if they have a 4spd one.
pro ratchet,
the hurst quarter stick looks the best IMO
As a note, I do not think the "perf shift" idea would work.
Reason being is when you shift up from low 1 to low 2, you're not shifting into 2nd gear, you're just unlocking 2nd gear allowing the car to shift into second once it reaches it's shift point. Essentially it would just never shift. Stock it already does what it sounds like you want it to do. If you leave the car in low 1 it wont shift to low 2 until it's in both low 2 or higher, and hit whatever RPM it shifts at. So you could essentially red-line it and then toss it into low 2, etc etc.
But that's all a really ****ing stupid idea on an auto. That's why tap-shift was invented, but tap-shift also sucks donkey cock.
Get a manual or do a manual conversion. Or just leave the car in drive.
these shiftier really do jack for a cars like ours. like mater said i think, they were made for full manual valve body trans, where you had to shift it, with this type of shiftier you wont skip a gear, neutral, or hit reverse.
Pretty sure I said what seangtp said.....![]()
for looks it will be cool, some of them are a lot of work to operate tho, some you need to pull a lever then pull the whole handle up, then ratchet it back. some are smother than others for sure.
do a write up, id like to see how it all turns out.
Thoughts?
my brother had a B and M in his chevelle, he also had a th400 build by B and M, with a full manual valve body, and a 3200 stall, and yes 12 second car. this puppy used to break the tires at 30 mph, and chirp 2nd and 3 rd with out even getting on it, just slap it and it chirped every time. also had a 600 + hp 462 BBC, cost 7,000 in parts just for the engine. (in 1988)
smoking up the slicks on the street
I'm already lightly snickering at the thought, and a bit more when the thought of a reverse manual VB was brought up for a 4T65, but If I saw a Pro-Ratchet or Bandit in a Grand Prix, I'd absolutely soil myself laughing.
Heh. You Are new.
