Anyone have a pic?
I have a 99 so I think I might not run the rear 02 but the front 02 is pretty taught right now and the engine is still like 6 inches from being in place
Sent from my SM-N900P using Tapatalk
Wait until you get it all the way in first.. Worse case you'll need a extension but no sense in jumping the gun until everything's in place
Alright. I think it'll work. Since when I raise the subframe into place, everything else should come with it
These?
Not sure where this plug goes? I'm thinking the plug in to thr right of it? Which I think won't be reachable until the subframe is reconnected.
first pic looks to be the abs harness. like i said before it will only fit if it belongs there. so try plugging it in where it looks to reach. that could also be the rack and pinion plug.
second pic is the driver side of the tranny theres a round plug there. push it on there. you may have to squeeze the two side to make it open up and click on.
Alright. I think I figured those out. Scotty, any idea of 3 pics up? Looks like a positive and negative of some sort. Also,
Not sure what this is? The bent thing and it has a small hole on the bottom
thos look like the battery cables, the red one goes to the starter, the black one goes to a bolts with a stud and nut on it on the front tranny bell housing. its right above the starter pretty much. with the black fat cable, theres 2 more sets of wires with a eye loop at the end, they also get put with the balck calbe on the tranny.
not sure what that is, need a better angle of it. but if it dont look like it plugs into anything it may just dead end there and be ok.
Alright. I kinda see where that cable attaches to the starter. There is a groove for it. But the black one goes to the bell housing?
you must have missed it.
I must have. and I'm not finding a diagram or picture on google of what everything should look like
look under the exhaust cross over pipe where the tranny bolts to the engine, the top front bolt (bumper side) has a threaded stud on the bolt with a nut to clamp the ground wires down.
the fat black one, and two more normal looking wires with eye loops. all 3 go on that stud, those are your main grounds.
the one on the left looks to be it, the one that would also look to hold a harness in place too.
dont ape the nut on, nice and tight, or you can break the stud off. and we dont want that now lol
Lol I've broken enough bolts/studs on this project to last me forever. I have the ability to somehow without trying to terribly hard break things =P
heres how to avoid that, when you think it needs another 1/4 turn, dont do it. i got a friend who just dont know where tight its. breaks crap all the time. then i have to fix it lol
bolts just need to be tight, turn it in till it stops going in, ( by hand or by socket) then a 1/4 turn more tops. thats tight enough for most bolts. they dont need to be aped on at all.
Lol thats good advice! So question, which wires go to that stud?
the fat black cable, and 2 more normal looking wires with eye loops to fit on that stud. iirc one eye loop has 3 wires, the other has 2.
what happened here? your putting it back together but did not take it a part? or has it just been apart for to long?
